ecm swap
shaun mccall
If i use an 86 87 ecm for an late 80,s early 90,s with an 3.0 3.8 can I also use the maf sensor or any thing else too that is needed to swap?
Your Maf
Shaun
You need to use an 86/87 turbo maf ,you can use a late 80's ealy 90's Ecm and Mat sensor ,and as far as the coil pack either switch the calpack from you 84/85 ecm (thats inside of the ecm next to the chip ,it looks just like the chip) Or swicth over to 86/87 coil an modual . Another thing to do is call casper's and order the kit and sensor ,they have just what you need
Good Luck
Get that Engine done right (dont fool around) machine shop does not seem to know what they are doing
Uwe
