Installed a new Edlebrock timing chain into friends car last night but had a question. With the new set i put the crank gear on at 0 for no advance since it had 3 key ways to go on. i installed the chain and cam gear and when the dots are line up perfectly the crank key way is not straight up and down? Now when the car is at perfect top dead center and the balancer is installed its a good inch past the timing mark with the line in the balancer. Is this correct cause im having a hard time figuring out why at TDC the mark on the balancer is not where it once was. motor turns over perfect just figuring this out for cam sensor install? Thanks for any help guys.
