Electrical connections
Luckydog32
I have 2 electrical connections that I need help to figure out where they go. 86 GN thanks
They don’t go to anything one i think is a tachometer signal and the other I believe has to do with the fuel pump but not sure.
That’s what I kind of figured when I couldn’t find the plug they went to. Just wanted to make sure. Thank you.
The green connector is a tach test point. The other connector is to run the fuel pump manually if you apply +12V to it.
Just make sure they cant touch something and go to ground.
