Electrical Problem
New Altternator No Power Off The Bolt On Back Could This Be Reason Car Dies Under Wide Open Throttle Is Computer Starving For Current And Would O2 Make It Run Ruff And Sh1tty
run a fairly heavy wire from the post on the back of the alt directly to the + terminal on the battery- the bigger the wire the better. also, make sure the red wire from the alt plug is looped back to that terminal, as well.
also, does the alt light in the dash work with the key on but the engine not running? if not, find out why.
i had to take my instrument cluster out and clean up all the contacts to get it to charge.
doing that should help a bit if you have a charging problem.
