Additionally, I noticed GA uses the following emissions test for 1996 and earlier: ASM2525 and no load idle test. If GA requires a specific gear selection during the test (CA requires drive), then by the time the vehicle reaches 25mph, it will be in 3rd gear. The EGR and catalyst are the two emission equipment that will have the greatest affect on NOx. The EGR is commanded on in 3rd gear and the cat only needs heat and no exhaust leaks prior to the cat (especially with a three way cat). Exhaust leaks promote combustion and there is a chamber in the three way cat that tries to put out the completion of the combustion process, in an effort to control NOx. If you have a exhaust leak in front of the cat (where the NOx bed is located), this uncontrolled air may promote combustion, and create a NOx problem. The second bed of the cat is for the control of HC and CO. There is a substrate material in front of the oxidation bed that coated with Cerium, a material that attracts O2. As the HC and CO passes into the oxidation bed (of the three way cat), the O2 is released to convert HC and CO to CO2 and H2O (the byproducts of perfect combustion).
