Engine block drain size?
SS/GN
What is the size of the coolant drains in the side of the block?I would like to put rad drain valves in to empty the antifreeze when I do a sevice on the cooling system:confused:Thanks in advance
Kevin
not positive, but i think they are 1/8" npt.....why not just flush the coolant completely out with engine running?
Thx
Thanks alot muchly appreciated.:biggrin:
Kevin
Those plugs are PITA to get out with engine in car. May want to heat them a bit. I've rounded my share:smile:.
