williambavila
William Avila (The Buick Guy)
- May 11, 2010
I have came across 2 engines lately that seem to crank like a busted timing chain or broken timing gears. They turn over like there is no compression and clacking. I have removed 1 and disassembled it looking at each piece carefully. I cannot see anything damaged. The only 2 possibilities that pop into my head are 1) the engine lost its prime and lifters are not pushing the pushrods up but it should not rotate as freely as possible. 2) the lifters are stuck up causing the valves to hang open regardless of position. I recently heard someone say it could be caused by the little plunger in the oil pump hosing being stuck. Has anyone had this issue or ran across it?
