TurboTnZ06
Go on red!
- May 7, 2002
This is off my running car 87 TR. Prices plus shipping, most likely USPS priority is cheapest.
SOLD - Three used amber front turn lenses, two RH one LH. $20 for all 3.
SOLD - Stock intercooler fan $5
SOLD - 1 unused crank sensor (in the sorenson box) $10
SOLD - 2 bar stock MAP sensor $5
SOLD - Beat up stock IC shroud $5
SOLD - Manual side mirrors, needs paint, they were loose but sorta worked if set them by hand outside the car, the internal adjusters are there but don't really move the mirrors, 200k miles on them. $5
SOLD - Complete cam sensor - I had GNS rebuild my spare sensor, never used it after rebuild, should be just like new. Comes with new cap. $300
SOLD - Grooved style billet throttle body top vacuum block, does NOT have vac brake port, though you could probably tap one in. $25
SOLD! Engine harness- oil pressure sensor plug cut off as it melted when I pulled it off back a decade ago and I didn't want it shorting (easily fixable), has lead spliced for MAP sensor for alky kit, and has been tapped for casper's knock gauge lead near ECM. Otherwise, it's a 30+ year old work of art. $150
SOLD - PTE turbo saver converted to -10 AN fittings and black braided lines. $100.
SOLD - Alky pump for alkycontrol- had my spare alkycontrol pump rebuilt by Julio, never reinstalled - $125
Sold - Turbo Tweak 6.1 chip burned for alky, low-mid 10 sec combo, and stock impedance 80# siemens injectors $50.
SOLD - Three wastegate solenoids -$20 for all 3.
