SignUp Now!yes it was even for gorilla hands like mine.:biggrin: once the tranny is bolted up you can lift the combo up quite a bit (with the rear tranny mount bolts loose)and bolt up the engine mounts .I cannot picture how are you putting the wires on the starter when is bolted up to the block since there is not a whole lot of room - I especially dislike putting on the little ones on the solenoid .I guess I am going to have to try that.
Get a 1 wire weatherpac connector with 6" of wire & hook that one up to solenoid on the stand. Then hook up weatherpac connector when motor is in. I have done that to a few wires. Get the kit from Caspers for $100 & you will never need another connector set. Makes all the hard to reach wires go anywhere you like.
Thats a pretty good idea..
What do you do about the large starter wire and others that connect to them:biggrin: j/k
BW
