Engine, Interior, Exterior, Brake Parts 4-Sale
87 WE2
Engine Parts:
Kirbans reproduction PVC & Map sensor metal vac lines for the vac pod $18 new in the bag.
THERMOSTAT HOUSEING, OK SHAPE $5
NEW 195 DEGREE THERMOSTAT $5
K&N Air Filter for Stock Air Box $20
CAM SENSOR DRIVE (MAKES NOISE, NEEDS SHIMS) NO CAP $35
WORKING EGR VALVE (NON AC DELCO) $ MAKE OFFER
LOW MILAGE - KNOWN GOOD EGR SILONIDE $40
NEW IN BAG, AC DELCO 87' RUBBER OIL PAN GASKET $25
HEAVY DUTY INTERCOOLER TO TURBO COMPRESSOR HOSE NEW 10 MILES ON IT WENT TO BIG NECK INTERCOOLER $10
Stock Turbo Oil feed line $5
Transmission Parts:
NICE STOCK 200 R4 TRANS PAN PILOT HOLE DRILLED FOR ATR'S DRAIN PLUG $15
Brakes:
EVERYTHING NEEDED TO CONVERT YOUR TURBO REGAL TO VACUME BRAKES.
CONVERSION KIT COMES WITH:
VACUUM BOOSTER W/ CHECK VALVE (Bad Booster good for core only)
MASTER CYLINDER ASSEMBLY (New, tested good)
ALL HARDWARE INCLUDED
BRAKE PEDAL ASSEMBLY
INSTRUCTIONS
1 KIT AVAILABLE $75 obo
Exterior Parts:
CHROME WHEEL WELL MOULDING - DRIVER SIDE FRONT $15
CHROME WHEEL WELL MOULDING - PASSENGER SIDE FRONT $15
CHROME FRONT FENDER CORNERING LIGHTS (PAIR) $45 obo
PAIR OF DOOR VENTS $10
2 REGAL EMBLEMS GOOD FOR DAILY DRIVER $5 EACH
1 BUICK TRUNK EMBLEM GOOD FOR DAILY DRIVER $25
GN TRUNK DECK LATCH ASSEMBLY $15
GN TRUNK DECK LIGHT ASSEMBLY $10
Interior Parts:
87 T STEERING WHEEL CENTER MEDALION NEAR MINT $8
Brown Horn Pad $15 - Sale Pending
Pics are available upon request.......................Thanks for looking.
Trunk latch Assembly
If the latch assembly includes the lock and key I will take it. Shipping would be to 76140, let me know how much.
Thanks,
Marty
Re: Trunk latch Assembly
Thanks, Marty
Sorry no lock & key.
Re: K & N Filter...
Originally posted by Cool87GN
Do you still have it & what size is it? thank you,
Its the round one that fits the factory air box.
