What are you folks seeing for engine oil pressure hot,at idle & in gear.Please tell what viscosity oil you are using,the approx outside temp,rpm & bearing clearances if known.
i run Discount Auto (made by valvoline) oil. 10W-30. i run around 20-25 psi hot idle and about maybe 50-60 psi @ WOT id guess but id have to go check to be sure. dang man 3 psi oil pressure, that kinda low maybe your guage is broke. i dint think a car could safely be that low on oil pressure.
