engine parts
WeSS
I gotz 2 sub woofers
standard bore 140 block 20 bolt pan with oil drain return $100.00. 8445 unported heads with recent valve job, didnt smoke, $150.00. Stock valve covers painted black $40.00. Stock uncut turbo shield $30.00. Stock flywheel $60.00. Stock gm front cover $40.00. Stock pistons on 2 dot rods $50.00. 87 gauge cluster with working boost & tach option for gn $60.00. 86-87 t type/turbo t metric stainless lugnuts set of 20 new $25.00.
Eng parts
I an interested in eng.block & rods,flex plate can pickup with cash. Call Me ED @ 941 639 2011
thanks for the reply
I will give you a call after lunch.
I also have a good used cam sensor for $50.00.
I am interested in the gauge cluster
I need the tach/boost section if it works properly. If you are not willing to sepereat I will purchase the whole thing. Have pics?
sent you a pm
it all works great & I want to sell the whole thing.
