SignUp Now!The only problem that goes through my "novice" mind is that being attached to the strut tower, the engine is pulling more torque on the already twisting unibody. I suppose this could be countered with a tower brace, which I've been planning on installing.
If you wanted to get crazy, you could add sub-frame connectors, but that requires welding (bolt in are not as effective) to the frame.
If they are bolt ins, why not remove them and put some others on...or just weld in the bolt-ons that are already on there... Yes, bolt on SFC only work for a short time if at all. The TTA DP / exhaust poses a problem when installing SFC's, so your installer may have done all he could there if thats the part you are referring to.I already have subframe connectors. If I could only go back in time and order different ones though. I got bolt-ins. They actually seem to work pretty well but I'm really not impressed with what my mechanic did underneath my car to make them fit![]()
For the tower brace, it should not require any drilling, all the ones I've seen for various cars bolt to the strut bolts sticking thru the tower..if the struts aren't tied together to make the pair rigid it kind of defeats the purpose....that said, I have not ever seen one on a TTA in person.
