leave it in D
dont lock the converter
or
more boost =more hp =go faster =more rpm at traps
really dont know why you think you need more RPM??
my biggest goal was less rpm at traps (was over 6200 at 130 on a 28 ,3.42 and 3rd gear) so went with a low slip converter and then i ended up dropping the rear gear ratio , now trap is 5800 and mph is now up 14 mph
if you're just after a higher rpm at the top of the shift ( which is not what your post asked ) governor weighting could do it but its best to experiment by just manually shift the gears and see if the car likes the higher rpm and what rpm is ideal .
