Ricky Trussell
- Feb 28, 2003
I am having some problems with engine stall when first cranking. I have the engine cranking fast but dies after about 3 seconds. It only does it one time or possible two then stays running.
I have been moving the setting up more but do not feel right about having the setting at 67% at 61 degrees.
This is a new set-up, going from N/A to turbo with a lower compression engine but all else the same. I am way beyond my old setting on this and still have the problem.
It seems fat when it does stay running so I am wondering it I have the decay rate set to fast??????
383 8.5 to 1
232 dur. cam
72lb. injectors
Afterstart enrichment settings
71% at 16 degrees
69% at 30 degrees
67% at 61 degrees
61% at 84 degrees then falls off rapidly.
afterstart revs before afterstart settings
39 at 16 degrees
18 at 39 degrees
8 at 61 degrees
8 at 84 degrees
Afterstart decay rate settings
****44 at 30 degrees
****24 at 61 degrees____ could this be it?
Start IAC pos. vs coolant temp settings
85 at 16 degrees
75 at 39 degrees
65 at 61 degrees
58 at 84 degrees
383 8.5 to 1
232 dur. cam
72lb. injectors
71% at 16 degrees
69% at 30 degrees
67% at 61 degrees
39 at 16 degrees
18 at 39 degrees
8 at 61 degrees
8 at 84 degrees
85 at 16 degrees
75 at 39 degrees
65 at 61 degrees
58 at 84 degrees
