81LimitedT
- Jun 5, 2001
We have an 85 140 series 3.8 (20 bolt pan) going into an 88 4x4 Ford Ranger with an '80 Carbed Turbo setup. Stock simple rebuild on the motor- no major upgrades. OUR Challenge is the motor w/ stock center sump pan is located directly above the engine crossmember and the rear TTB suspension mount. We can obviously lift the engine higher in the frame for clearance, but it would necessitate lifting the body another inch or two. (My son's truck and he wants to stay with the 2" suspension lift and 1" body lift.) It looks plenty high enough now- Kinda in a stuck spot here. Anyone have any thoughts or ideas? The only non-stock pan I can find is the deep sump RJC and that will just make the problem worse. Thanks for any help!
