Engine Wiring Harness
TTipe
Snake Skinner
Do the engine wiring harness leads (with the fusible links) going to the starter have a conduit over them to protect from heat of contact with the back of the engine?
Yes. Special conduit, with a blue stripe is used for that run. It's high temp material, 10mm diameter.
Do you sell any of that conduit?. I have looked for the high temp stuff (blue stripe) before and I have not been able to find it
We don't sell it, we use it in production. Send me a PM with your address.
John
You can get grey stripe split loom tubing from wiringproducts.com listed under Hi Temp Nylon Loom. The grey stripe has a slightly higher temp rating of 300 deg. vs 275 deg. for blue stripe, but blue stripe has a fire retardant for short circuits $8.75 for a 10' length of 3/8". They have 1/4" through 1" 10' lengths and 100' rolls. Sam
