the engine is still in car and runs, motor does make a slight noise at 2600 rpm. my builder says sounds like wrist pin but obviously wont no for sure till it comes apart. motor makes 60 psi oil pressure still. block has steel center caps and je pistons, rest of block is stock. also I have gn1 aluminum 14 bolt heads ported by champion heads will be bare. short block 1,000 heads 750 or best offer.
