buickturbot
- Mar 18, 2006
is enlarging the two center main oil feed holes good or bad idea?
SignUp Now!my oil pressure is 75 cold & 45 at cruise and 25 hot, if you do it right you will have great oil pressue.
you need to drill the bearing to the same size whole, so the oil flow's smooth.
You'll find the main bearing oiling passages are 9/32". The main bearing oiling holes are smaller. You can drill and chamfer the bearing oiling holes to match the passages. This will increase oiling somewhat, without getting into drilling the block oil passages.
Louis L.
But i do believe that drilling smaller holes in the cam bearings and reclocking them prior to install is a more worth while procedure. Ive had this done in every one of my motors(2 109s n Stage 2) and never have had any oiling problems.
I'm lost. (not trying to be smart) but, how does one drill smaller holes? if you drill an existing hole its going to get bigger. or, if you meant drilling a new hole, drill it bigger...than what diameter? (im trying to learn)
