Hello. I recently removed my intercooler and cleaned it. Did it ever need it! Before reinstalling it I wanted to take the boost down a few notches, just incase I got more boost to the engine with a cleaner IC. I have really fine thread pitch on my wastegate, and to be honest, I'd never adjusted it before (I always ran 18psi). I took it down about ten turns, figuring this would drop 5 psi or so (I know 1 turn per 1 psi is typical, but this one seems to be finer threaded.) There was VERY little tension on the wastegate puck when I hooked her back up. Okay, time to light it off...
It idled like I unplugged a couple plugs. Really slow, really erratic, and really rough. Usually the car idles fast, but it was on the verge of stalling here. I think maybe I took too much out've the wastegate. So I tightened it a little. It ran a little more smoothly. The SERVICE ENGINE light was on, and it topped out boost at like 11 psi. So I tightened it a lot more, little TOO much. Next run, 15 psi, and the S.E. light is still on. Right before I got home the SE light went out. Cool, so I took her for a high-boost run down the street. The needle shot to 20 psi in NO time, and I got out of it.
So, loosened up the wastegate some (like 5 turns) and ran again. The boost went to 19psi, then quickly dropped to 16ish, then flickered between 16 and 17. Really erratic.
I was wondering if that 20 psi accident hosed anything up? What would cause the boost to be so erratic? Knock retard? Did I hose up the wastegate (the rod connecting to the "can" was turned a couple times accidently)? Would the clean intercooler play a role in all this? Thanks a LOT!!
Whoa, sorry for the LOOONG post. BTW I ran O2 safe fuel injector cleaner through the intercooler (FOUR bottles), poured it out, then filled it with water and let it sit. I THINK it was very dry when it went back in. I run 93 octane with that 104+ octane boost stuff. Thanks!
