It is time to ditch the R-12. Initially I was just going to put a new dryer in, pull a good vacuum and go back with R-134A. Since the front seal was slinging a little oil, the new plan is to pull the compressor, tear down and reseal. I will take Turbo6inKY’s advice on the RockAuto condenser and replace that too.
Does the residual mineral oil in the hoses and evaporator amount to enough that I should use ester oil or is it best to go with PAG? What weight PAG is recommended? How many oz in each component?
Anyone know what size adapters are needed. Low side looks like 7/16” and high side 3/8”?
Sent from my iPad using Tapatalk
