I sealed it with the copper RTV and letting it sit over night to see what happens.
I also seen alot of theads about the trouble with ATR uppipe and header connection, which i have. But i had this same problem b4 the swap to ATR exhaust system... Could there be a leak coming from some where else? i also seen threads about not using gasket on the header? I have gaskets on!
I belief the copper coat is only rated to 500F.
The high temp silicone is rated for 600F, but has proven to hold up well in our applications. :wink:
The way I do it is:
Add the sealant to the joint, install the pipe, and torque to 50-75% of final value. Let is cure, and then finish the torque.
In my opinion;
-Factory did not put in a header gasket. IMO, “if” you decide to use a gasket, run the copper to transfer some of the heat. I have no data to back up this statement.
-I have installed header gaskets and by doing so moved the headers out enough to create fitment issues.
-My “ATR” up pipe was seriously off to the point it was unusable! The overal workmanship was good but the fit was horrible
. This was resolved through customization.
Get the up-pipe from Jay, and sell the ATR.
Unless you have a TIG welder, this option will be cheaper in the long run.
