Exhaust question
eagleguy
No cat stock diameter dual exhaust out the rear. I find that the current mufflers give me a drone noise which I am not too fond of. Any ideas for a nice sounding pair of replacement mufflers. I do not know the current brand in the car. They look plain Jane. Not many cars in my area to listen to!
2.5" Dynomax Ultra Flow Welded. Straight-through design, which is what you want, has a nice tone to it (subjective) and most importantly does not drone.
Keep in mind should you decide to switch to 3" that changes everything. I've heard of some running the 3" Dynomax Ultra Flo's and getting drone. Your build will affect sound to some degree as well.
This is all the mods to my car at the moment.
ta49 turbo
36# injectors
160 thermostat
100# comp valve springs
turbo tweak chip
fuel pump w /hot wire kit
I would really like to stick to my 2.5" system if only doing the mufflers as its in nice shape. If going to 3" makes a difference I would consider going all SS. Don't mind some rumble but NO DRONE NOISE.
