Nov 11, 2005 #1 O only6 New Member Joined Nov 10, 2005 Messages 6 I am getting strange readings using Turbolink 2.1 and the Extender extreme chip. Is Tlink 2.1 compatible with the extender extreme or must you run version 4?
Nov 12, 2005 #2 M mweber Member Joined May 27, 2001 Messages 134 It depends which data stream the chip is programmed for. To work properly with Turbolink 2.1 the chip must be programmed for the stock data stream. Mike
Nov 12, 2005 #3 O only6 New Member Joined Nov 10, 2005 Messages 6 That 'splains it. It is not programmed for the stock data stream. Thanks!
