Chrisk
TurboTransAm.com
- Apr 12, 2005
Im going to be installing a B&M cooler with fan.
The cooler comes with no install hardware so I will have to gather everything.
The cooler has 1/2" npt Female. Im not sure what is on the oil adapter on the car. I think 1/2" as well? Is this correct?
I was looking at getting 2 Straight, -8 AN male to 1/2 in. NPT Male to come out of the cooler. Earl's Performance 981688ERL - Earl's Performance AN to NPT Adapter Fittings - summitracing.com
Use this fitting to connect to rubber hose from cooler to adapter. Summit SUM-2200076B - Summit AN to Tube Adapter Fittings - summitracing.com
And this into the adapter Summit SUM-2200078B - Summit AN to Tube Adapter Fittings - summitracing.com
Is this correct?
I also have to do a trans cooler..
Thanks for the help...
Chris
Is this correct?
Chris
