Any advice would be appreciated.
I purchased an ATR 3" DP with a deltagate on Ebay with an air regulator. I installed it and it is set at 20psi. Everything works great, what I am wondering is which one do I adjust to raise the boost...the air regulator or the deltagate.
I figured if I turned the allen screw in on the deltagate I would increase pressure on the spring thereby raising the boost. Is this correct? What effect does the air regulator have on the system?
I have not made any adjusts as of yet for fear of putting too much boost in the motor, I dont know how sensitive the adjustments are.
Thanks in advance.
Thanks in advance.
