External wastegate vs stock?
davidf
Whats the benefit between the 2 other than a seperate downpipe needed? Thank's.
External gates provide a stable amount of boost. Internal gates can sometimes allow boost creep, external gates pretty much eliminate that.
rock solid boost with an external gate, no more creep for me
You also can lower your boost farther down than you can with an actuator depending on how your external gate is setup. Thats beneficial for traction if you're using an electronic boost controller that lets you control ramp speeds.
The last downpipe we did for a guy in the shop, with a TurboSmart 50 gate we could lower the boost down to 5 PSI with an ISAC.
