Hey guys,
I have a question about my F.A.S.T computer and decelleration. I have the a/f ratio set at 14.5 when I get off the gas, and my VE numbers are around 50, but my actual air fuel is way lean at 15.9, but if I actually add VE numbers to match the 14.5:1 air fuel ratio, the numbers are huge, like 7x.
Also, in neutral, I give it a quick rev and let off, and every now and then it'll make an airy pop, is this due to the lean condition? What should the timing look like on decelleration, more advance, or less? What should I do about the lean VE numbers, should I just correct them even though the numbers match my WOT VE numbers?
Any help is appreciated,
Thanks.
Thanks.
