F.A.S.T. install question
HiTech6
I am ready to install a new FAST and would like to know where you mounted the computer. Any ideas and photo's. Thanks for the help.
WEll it depends on which jumper harness you use,With the PTE version,I put the fast computer in the stock location,WIth the FASTTRACK harness the fast ecu was under the pass seat
FAST install
Thanks for the reply. Not sure which I have except I know it came off a car and it was mounted under the pass. seat. Thanks again.
I mounted mine inthe stock local to the kick panal using the top cover to cover the ECM.You would never know the stock ECM wasn't there.
