I have a 96 4v mustang on fast that is giving me a ton of trouble. It is a built engine, fully ported heads, stk. cams, long tube hdrs w/off-road h, street renegade 1000hp fuel system, originally had holley 95lb inj, then went to siemen decka 42lb inj, and now I'm on 42lb bosch, procharger D1-SC 16-17psi @ 7000rpm, msd DIS-4 ignition. That's about all I can think of to give you the run down of the car.........My problem is it wants some stupid jacked up #'s in the VE table. example: @ idle 69-70.......@ part throttle (my problem area) 120-150.......@ peak load/torque 90-95.......@ WOT 115-120 (just to be safe). I've gone through my set-up 1000 times and it's all correct. I even took a program from another car that has basically the exact same set-up (with no problems) and tried to load it and run it in my car.....no way did that work. If your in 4th pulling through your tables the AF reads lean, but if your cruiz'n in the same cells (kpa vs rpm) in 6th it's fat as a pig. One last thing I noticed yesterday. On your enrichment % vs coolant temp and enrichment % vs tps position my damn bubble is off the chart.....max'd out 100%. Wuz up wit dat?? At this point and time I'm up for suggestions. ANY suggestions!!!! There is nothing more frustrating than chasing your azz
