f body aluminum drums fitment
yes you can... they are the same brakes as the g bodies...
thank you very much for the info
Alan
I remembered that from somewhere but wanted to make sure
I know they fit, the only difference from aluminum to steel is the alum is a bit thicker, spacing the wheel out like 1/8" to 1"4" right? I will try to find the info. This is actually a good thing, as usually the tire is closer to the frame than it is the wheelwell lip. Anyone else see this?
