F body radiator... HELP!
BoostedTtype
Im in the middle of a f body radiator install and the trans cooler lines are no where near close to where the f body radiator inserts are. My stock radiator had the trans cooler lines ran to the around the front but the f body requires them to be ran straight into the back near the radiator hose. Has anyone dealt with this?
I don't want to use a separate trans cooler. What are my options?
you have to make your existing lines match the Fbody unit if you don't want to run an external cooler.
oh yeah, the cars make a lot of heat.... run an external cooler :)
I have read that's what everybody is doing but I cant see how the stock lines could possibly stretch that far. They seem to be way too short. Has anyone done this?
They will fit. I have a f body radiator in mine. You will have to bend the lines a little bit. You also have to remove the sandwich plate for the engine oil cooler. It made my car run a lot cooler.
Please post a pic if You can. I really can't see a way to bend these lines.. They seem to be way too short.
Sent from my N861 using TurboBuick Mobile mobile app
I had to extend mine with barbed splices and hose. Hopefully
you can see this on the pics. I also added a B&M external oil cooler.
