F/S One black GTA Rim
my85grandnation
85 Triple Threat
I just bought a used set of Kirban GNX look alike wheels, but when they showed up it turns out that one of the wheels is actually a GTA Rim. I want a matching set so I ordered one wheel from Kirban and I have no use for this wheel now. It is marked rear, but I have the a spacer so you can use it on a GN if you install longer studs. It currently has a fairly new Nitto P245/50R16 mounted on it, but I havent decided if I will need the tire or not. The wheel is in good shape with only a couple of nicks on the outer lip. It needs a good clean, but I believe it will shine up great. I will sell the wheel only for $100 shipped, and if I end up not needing the tire then I would sell the wheel and tire for $200 shipped.
