Fab 9 complete rear
Otto J
I have a Fab 9" rear for sale / backbraced and powder coated black
Mark Williams through bolt Center section
Strage 33 Spline Gun Drilled lightened axles/ lightened spool
3.50 pro gear, large aluminum bearing support
Strange disc brakes with spare rotors
Caliper brackets setup for dual calipers/ only coming with single caliper.
Custom upper and lower control arms with spherical rod ends
and wolfe anti roll bar.(you will need to purchase the wolfe bar ends)
asking 3300 with everything
Will post pics tonight
Can deliver to Norwalk in 2 weeks.
pics
That is a heck of a deal. Are you sure it is 33 spline axles and not 35? I cant see a MW thru bolt alum case with pro gear with 33 spline axles? Plus a gun drilled 33 spline axle would be pretty weak on a 1000+HP 3400+# car:confused:
Was told it was 33 spline.
This is the rear out of Tony Gomes' car.
so its proven to run into the 7s without issue ;)
He believes they are gun drilled and they are defintely lightened flanges.
I will pull an axle tomorrow and double check though
They are going to be 35 spline. Nice deal wish it came around earlier I would've snaged it.
I thought the same thing Chris,but he was pretty adament about it being 33.
The other thing i did not mention is that the upper factory mounts were removed and replaced for the use with spherical rod ends that also correct the suspenion geometry.
They are 33 spline but they are not gunned drilled. The ring gear is also lightened, alot of money went into making it lightweight and low drag hope this helps.
