today I failed due to high NOX, here are the numbers.
vechicle state standard
HC 0.78 1.60 PASS
CO 4.34 15.00 PASS
NOX 2.96 2.50 FAIL
I am running a TT emissions chip set at 38psi line off, new cat all egr ports welded, new motor with 224/224cam 50psi injectors, ported heads, 6152 turbo. The coolant temp was at about 198 to 201 for the test and outside air temp about 101 degrees. I had a full tank of 91 octane gas, my question is would d-natured alcohol do the trick or something else? And if so how much to add to the tank, fuul or empty? any help would be greatly appreciated.
HC 0.78 1.60 PASS
CO 4.34 15.00 PASS
NOX 2.96 2.50 FAIL
