False knock?
chevellejoe
Just hooked up a powerlogger, recorded a pass to see were my car is at. Anyway I noticed my knock retard went to 1.8 deg between 3500 and 4800RPM in first. Second gear no issue and third i got off at 90mph but no issue as well. The Knock counts shows none thru the whole pass and o2s are at 862mv. Is this something to worry about?
Nothing to worry about. Knock in first and second gears is generally false. Third gear is the killer. :eek:
yeah i feel the same. i just got the car and im going through it. i figure i will raise the boost one or two psi and see where im at.
