Fan clutch
I was told it would be better to leave it on, cause it's just going along for the ride. The flex was turning at all times. I'm running a flex now, idk if I should take it off or not.
How much will it benefit me to remove the fan clutch?
Depends on the benefit you are trying the achieve. :)
Typical HP benefit listed on the www at about 10 hp.
AC, coolant temp and engine bay airflow/temp cooling benefit from removal is negative xx.
We want air flow to keep temps in the engine compartment in check for both AC/cooling and HP (heat soak).
