Fan Help
meach13
Narrow A$$ Racing
HAVE A 87 GN JUST PUT FAST ON IT AND THE FAN WILL NOT CUT ON UNTIL 200
HAVE CHANGED THE SETTING TO 160 STILL NO CHANGE
i thought that was only one setting under system config fan on temp and fan off temp
Right- "high" = on, "low" = off.
Which one did you set to 160? What is the other setting?
OK, next question... sorry if this seems too obvious, but 200 degrees on what gauge? Was the laptop telling you 200, or were you looking at a gauge in your car? Are you using the stock sensors in your GN? If not, you should be.
looking at the autometer gauge which reads 193
and looking at the laptop reading which was 200
it has the stock gn temp sensor in it
could it be something in the wiring harness from P/E
i have a switch on it grounding the relay out until i can find the problem
