Fan Help
USMC_Turbo6
Well I put a new aluminum radiator and 2 fans in my car. I got the wiring kit from racetronix and they told me that I would need to put a switch for hi/lo speed for the fan because my car still has A/C and I don’t need the run on hi all the time. I looked everywhere around where I live and can’t find you. I have a kenne bell ashtray switch with the 6 switch in it will that work or do I need something other than that?
Why not run them from the stock wiring & relays? If one fan is smaller run it from the low speed fan circuit. The larger from the high speed fan circuit. And skip the fan delay relay altogether.
RemoveBeforeFlight
