Fan not turning on...Help!!
edub01
My fan is not turning on while the car is running. The cooloant got up to 230 degrees and nothing. After turning the car off, the fan kicks on for about 4-5 minutes. The coolant temp sensor going to the ecm was replaced recently but not the sensor for the fan. Any advice?
Well after messing with it for a while, I started the car back up and when it got to about 220, i tapped the fan delay relay with a screwdriver handle a few times and then the fan kicked on. So I am assuming its time for a new relay.
