bird
- Feb 20, 2003
hopefully going to the track this sunday. went for some test passes on the street, the target afr was at 11.2 my actual afr was close for first & second gear but dropped off to 9.19 and stayed their for the rest of the pass i had the timing set really low on the program (17.5 degrees at 24psi) for boost setting purposes only. could this cause that rich condiiton? ill obviously be turning the timing up at the track but if my wbo2 is fried i wont bother going. anyone run into this?
