Ok the blue red black and purple are easily spelled out in the instructions, but it does not tell you where to plug the harness part into, the online help in WP is the same as the instructions in the box. My guess is that it plugs into the C-Com harness, but this is where I have a problem, the wires in the harness that plugs into the ECU DL and the other end into the FAST C-com plug are not wired the same on both ends of the harness. in the A slot on one end I have a red wire, on the other end I have a black wire in the A slot......is this wired right? Do I have to unplug the ECU DL and plug my laptop directly into the DL to get the info out? sometimes the easiest things are so complicated....hehe
