I had the car tuned by a local turbo shop. The car was tuned on a dyno and I was told it was hard to do because my boost wouldnt go any lower then 19lbs. Now after 10 dyno pulls and 650 bucks for tuning it runs pretty bad at normal driving speeds. The car will backfire through the intake when cold and at idle it hunts for a steady rpm? It will sometimes die when I give it some gas and will hesitate before it picks up rpms. When trying to start it will try to run but never catch on and kind of stumble and die then I try it again and it will fire off. Makes plenty of power with only 18 degrees of timing he put in the car but these other issues have now krept up. Where should I start It is a stage II car with a heavy duty stock style wastegate hence the 19 lbs boost minumum. When I took the car in to be tuned it was really rich according to the Fast and the smell but the plugs looked great with a light brown. Now with an A/F of 11.0 the plugs are really black?? Thanks
