S
Stk1520
Guest
I had a Holley Strip Annihilator ignition system sitting on the shelf and decided to install on my '89 Mustang (with FAST FI system). I wanted to use the Annihilator's 3-step rev limiters (main, stage and burnout) so I installed the box in place of the trusty old MSD 6A.
Everything works except the tach (the VDO tach worked fine with the MSD box). The Holley manual says most aftermarket fuel injection systems require a tach signal amplifier. I just wanted to see if anyone else has run into this problem before I order the signal amplifier.
Thanks,
Jim K.
Thanks,
Jim K.
