FAST log files
Mad_Trbo
How do you log FAST log files, I wanted the board to have a look at a log or two I made and give some input on how things are looking.
Do you mean how do you record your run? Or do you mean how do you put the log you have recorded up?
What I do is snap a picture with my digital camera and then attach it..
Or send the .logs to your tuner and have him look at them. The performance ecm section of this board is really where this post needs to be.
HTH
example,
http://www.turbobuick.com/forums/showthread.php?t=174604
If you have already logged the runs, then they will be in the \ccomwp\log folder with the names you gave them when you saved them. You can email them or put them on a server someone so people can dl them. If you send them tome I will put them up for you.
If you asking how to log, then F2 to connect then F8 for logging then enter to set trigger or space to start logging.
Sully
