C
		cojo1
Guest
Does anyone know if the ecu sends a hot to the negative side of the fuel pump and fan relays? I have the bank to bank system and checked both negative sides which were hot when you check them to ground! I was under the impression that the ecu sent a negative signal to the negative side of the relay. *when I checked these the car was off*!
