Dominator vs Fast vs GNECU
The myth is try to make as much power as you can.
A top fuel dragster is not getting down an unprepared surface like a dedicated street car will
Just like a dedicated street car is not going to get down the racetrack like a top fuel car would
Carb or efišŸ˜‰
The Holley dash sure is nice addition to have. Also i forgot to add the way the holley applies the learning is excellent. However if you o2 sensor gets screwed up so will be learned data, so you need kind of limits its control once the car is tuned close maybe save that tune in case you have issue's one day. The o2 sensor can die slowly over time or it can be instant, but that happens to all ecu;s too.:)
That is true, also a good idea is just to keep a usb drive taped to the ecu case as well.
Since I have the dash I have multiple revisions of my tune in the dash so if something happens I can easily restore it. The whole thing where if it cranks with too low of voltage the ecu drops the tune is annoying but I have not had that issue since putting the car on a battery tender when it sits.
