I have a Classic SFI system. I recieved a startup program from Cal H.
I am trying to work out a bad off-idle hesitation or stumble if you will. It is serious. I am trying to pull out in traffic and blahh the car stumbles and goes dead half the time. The other half I am emberrased that someone can hear it sputtering.
Cranks and Idles very good.
Here is a log of a hesitation event...
Here is a pic of NO hesitation ...
The bottom grey line is the Injector Duty Cycle. You can clearly see on the NO hesiation log the duty cycle kicks up about 4ms. Is this the AE kicking in?
I am trying to correlate the AE vs TPS rate of change map to the log.
I can see the rate of change on the log, but the TPS is expressed in % and the AE vs TPS graph units are in cts/4ms. I do not know where on the curve do I make the change.
Anyhelp? Thanks
Anyhelp? Thanks
