FAST system w/ EVERYTHING....
5 LTR KLR
FAST Bank to Bank system with everything except Wide O2 harness and needs to be reprogramed for a GN (was set up for LT1). It will cost $40 to reprogram, 3 Bar Map sensor and $279 for Wideband O2 senor. Go another route now. Will take $875
#### NOTE: the FAST system comes with GN jumper harness (plugs into factory GN harness to FAST system), Laptop cable, MAP sensor harness and Wideband O2 harness. Everything needed to run this system....LASTLY was bought from PTE. Has PTE sticker on it.
Rod
E-mail: fiveltrklr@yahoo.com -OR- call 414-702-8787
Rod
your ad doesnt make sense..you say it has everything EXCEPT the wbo2 harness...but then you say it has everything needed to run including wbo2 harness....so whats the deal?
thats a pretty good IMO...but i'm un sure what is actually there...
I APPOLIGZE!!!: it comes w/ everything to get it to work with a facotry GN harness, the FAST system AND work with a laptop.
IT'S JUST MISSING: Wideband O2 sensor, 3-Bar Map sensors, reprogram the FAST system to get it to work for a GN, and the FAST software for the laptop...THAT IS IT.
###################### DO HAVE PICTURES NOW TAKEN, E-MAIL IF YOU NEED PICTURES!!!! #######################
:cool:
####### ONE MORE NOTE: "ALL" THE HARNESSES ARE BRAND NEW!!!!!!!!!!!!!!!!!!! #############
So how much do I have to spend on top of what your selling the system for.And what happened to the software it came with?
