I'm trying to tune my new FAST ecm, and I was having a problem with the car dying when you let off the gas driving down the road. I checked the throttle follower, and it was way high on the graph, when it should have been lower. So I adjusted the throttle blade open with the throttle stop screw, and the throttle follower graph looked good, and the car runs much better and doesn't die, but it raised my idle a couple hundred, which I figure it should since I moved the blade. The tps went from 5% to 11% at idle, so I adjusted the tps back down but the idle is still high, and when I start the car the rpms shoot up to 2000 for a few seconds. I'd like them back down to 1400 at start up, how do I get this idle down? It idles at about 1050 now, it was at 900-950 before. I thought adjusting the tps would bring it down, but no luck. And I can't get my tps to read 100%, only gets up to 85%. Is it necessary for it to read 100% at WOT? Thanks for any help!
